Is there a step function to verify the flightplan?
I am new to the Q400. My PMDG NGX and Aerosoft CR9 each have a step function to verify the flightplan input into the FMS.
Is there a similar feature in the Q400? Thanks.
Martin
  • Do you mean PLAN view on the navigation display? Press the FORMAT button by the display controls, then as you go through the flight plan pages on the FMS the nav map will move with it.
  • That is exactly what I was looking for. Thank you.
