Can someone suggest how to fix this? Run as admin, reinstall all that basic stuff has been done. Will have to end up getting a refund if this persists... which is a shame because the Q400 is a great aircraft.
If you have something called the Immersion Manager, then close it when using the Q400 as it seems to cause peculiar behavior which has been reported to the developers of ChasePlane/Q400 Immersion.
There very likely may be a third party influence causing this. Are you running the Q400 without any other addons?
Nothing other than orbx scenery and other 3rd party scenery and chaseplane
Oh I do have that... hmmmmm... will disable it and get back to you!
Yeah that seems to have fixed it. Thanks for your help mate, you're a life saver!
