P3D Pro Plus autopilot
I have installed the Q400 for P3D V5 in p3d V5 Pro Plus, the aircraft loads and seems OK , but when I engage the AP all functions seem to operate but the AP does not follow, eg.: select HDG mode , the bug moves OK , the label shows HDG in green , the AP is engaged but the plane flyes in circles.
Is this as result of the Pro Plus? or anything else ...
Please advise...thank you
Jorge
Sorry , this is fixed now , I reinstalled the AC and seems OK Now...
Jorge
Thanks for the update. Normally, as you have already done, a reinstall corrects the issue, and be sure that it is done as Adminstrator.
