Elevator Trim
I can’t find how to adjust the elevator trim while going through the checklists. It is reading outside the white range. Any help is appreciated.
  • It can be adjusted by assigned key, which you can set through p3d(or FSX) settings.
  • Elevator trim has to be assigned via the buttons section for your input devices. By default I think the simulator assigns the page up and page down keys, but these can be changed to your liking, and you can also assign buttons to your input device in that section as well.
  • Makes sense. Thanks!
