Reinstall configuration inquiry
Recently installed P3DV5. Discussions on the facelift upgrade led me to revisit everything Majestic Q400. I realized how much absolute fun and enjoyement I had both learning (some frustrations of course) and flying the Q400. Pulled my Q400 docs and Airline2Sim vids out of the idstant archives and moved them to my Surface desktop.
So... I'm about to use the latest installer from Simmarket to put the Q400 into P3Dv5. Also bought the recent upgrade. Should I install and fully configure (and get airworthy) the original install before applying the recent upgrade, or can I install both and begin the configuration of the aircraft, the CPAN and my Warthog setup.
Thanks!
Bob
Provided that the latest installer acquired from Simmarket is version 1.021then you will be good to go.
Installation process
1. Q400 Add-on
2. Visual Extension Package
