C&D state
Hi, after flight i tend to save scenario. I have made scenarios for all my fav planes. Next flight i start by loading saved scenario. Unfortunately automatic cold and dark state does not activate even such option is set in cpan. Is it a known bug or limitation ?
My sim P3D5.2, Q400 PRO of course
1. Open the cpan as administrator (this can be done with the sim closed).
2. Select the panel state of your choice.
3. Click the APPLY button at the bottom of the CPAN
4. Open the mjc84. Ini and check the status of the panel state
You speak of saved scenarios. Are they not loading in the state of which the scenario was saved? What I would suggest is to attempt loading the same scenario a second time to see if it loads correctly. We are have been looking for a solution on this issue as it was introduced in version 4
I assume that when loading saved scenario, then regardless of state i left my plane after last flight i will have C&D as such is set, but after loading of saved scenario there is even no green bar announcement about entering C&D. If i do not use saved scenario, but will choose Q400 from P3D start up menu, then C&D activates, so problem is only about saved scenarios.
