CTD when using FMS Copy PLT RTE function
Trying to load a plan from Simbrief. I read that when pushing the Copy PLT RTE button I should see a list of flight plans in the C:\Program Files\Lockheed Martin\Prepar3D v5\SimObjects\Airplanes\mjc8q400\nav\routes folder.
Instead of showing the files, it immediately CTD's.
Info from Event Viewer:
Faulting application name: Prepar3D.exe, version: 5.2.22.27615, time stamp: 0x60db69bf
Faulting module name: mjc84_main.dll, version: 1.0.0.0, time stamp: 0x5f00cd0e
Exception code: 0xc0000409
Fault offset: 0x000000000036eb58
Faulting process id: 0x4fbc
Faulting application start time: 0x01d7d9d924e40f50
Faulting application path: C:\Program Files\Lockheed Martin\Prepar3D v5\Prepar3D.exe
Faulting module path: C:\Program Files\Lockheed Martin\Prepar3D v5\SimObjects\Airplanes\mjc8q400\panel\mjc84_main.dll
Report Id: 6d4df1c5-f5a8-4ad5-869f-9bb06bb4e794
Faulting package full name:
  • 2 Questions:
    1. Do you have the files downloaded from Simbrief in the routes folder (I have to ask as some users fail to ensure that the downloaded files from Simbrief are properly allocated to the routs folder).
    2. What version of the Q400 are you using?
