Sounds dissapearing from cockpit when using ChasePlane
Hopefully this is my last support thread, I find when changing views with chaseplane certain cockpit sounds dissapear and only come back if I mess with the views again, any fix for this?
  • This can be dependent on how your pc is set up. A common issue is users having 5.1 setup when there pc does not have a 5.1 sound configuration
  • I just use stereo speakers, do i need a 5.1 sound system/headset?
  • edited December 2021
    No you don't. There are several post on the forum regarding loss of sound. Kindly take some time to browse through and say if one of the topics may apply and or help on rectifying your issue
  • Alright Ive looked around and nothing seemed to fix my issue, Apparently its an issue with how chaseplane and the Q400 interact, but if I just keep my camera in the cockpit its fine so I just wont leave the cockpit.
  • You can also give this a try and see if it may help
    Providing that you are not using Windows 8, locate the following line in the mjc84.ini file, located in the /ini folder inside the Q400 addon mjc8q400 folder
    Win7CompatibilityMode = 0
    and change 0 to 1
  • Alright I tried that and no ball
