FMS not turning on
I have the Q400 running but I am not able to start the FMC. The On button will simply not respond.
Recent changes are a new reinstall and addition of the latest patch.
Thank you. Rolf
Computer - Windows 10 Pro 64bit -  I7 7700K CPU @4.20GHz - GPU GTX 1080- - 32.0 GB RAM - P3D v4.3
    just to make sure. The electrical panel is set properly?
    Also, did you load in your payload via the MJC Control Panel? This causes the sim to pause.
  • Thanks. I am away for a few days but will check the electrical panel when I get back.I did not load the payload via MJC control.
    I appreciate your help.
    Rolf
  • The electrical panel appears to function properly. The FMC just does not respond to on/off. Nor do any other buttons until you hit the alignment button. That one works. There do not appear to be any other "Dead" areas that I have noticed. I should mention that the FMC worked fine prior to my last install a week or so ago. This was downloaded from the Majestic Software site.
    Any help will be appreciated.
    Thanks,
    Rolf
  • Let's start with uninstalling your Q400, and reinstall it. Be sure to install by right clicking on the installer as run as administrator
  • Thank you. I will do that and report back.
  • Success! That worked and all is well again.
    I really appreciate your help.
    Rolf
  • Thanks for the update
