Update advice Pro Edition
I have downloaded the latest update from Justflight. Should I uninstall or install 'over the top?
Keith
  • Hi Keith,
    If you choose to install over the existing installation then I recommend that you backup the liveries and the aircraft.cfg along with any other changes that you may have may to your mjc84.ini before proceedong with the installation.
    I personally prefer to uninstall and reinstall any addon unless it's a minor patch.
  • Many thanks!
    Keith
