LH Engine Oil temp needle missing in VC & 2D popup
As the title says, I've noticed that the oil temp needle is missing in VC and in 2D popup from LH engine instruments.
https://i.imgur.com/Wg3zKC1.jpg
[https://i.imgur.com/fk5ko7E.jpg
It's the first time I've noticed this, cant say for certain it was there prior to 1.025 update (which I'm running)
  • I can confirm the same missing needle. Pro version. 1.025.
  • Yes, we have the issue in the list of items to be adjusted.
    Thx
  • Me too.I think the needle is in the correct position but it has desapeared.
