Problem with weight and balance
I´m starting sim. Than i start "Control Panel" as Adminstrator. Loaded Aircraft and all was cold and dark as planned.
So far so good. But when i enter the data in the weight and balance section in the "Control Panel" and press "send to sim", sound in sim went off and i cant switch any knob or switch in the VC any more. I can still move in the sim, so no freezing but as said, no operational switches and knobs any more in the VC. Is this a know issue? Cheers, Stefan
  • Pressing the APPLY button to load the aircraft weights by default will PAUSE the simulator. Simply un-pause the simulator and you'll be good to go.
    Kindly take some time to read the manuals provided with the product for a better understanding of how the aircraft is designed to function within the simulator platform.
    Thank you for your support.
  • Thank you for you quick help on this and OK i will check the manuals. cheers.
