CPAN not saving settings
CPAN is not saving my settings. I have tried to edit the .ini file and it will not allow me to as I am not the "owner" of the document. Only way around this has been to drag the file to desktop, edit there and save, then drag back to the ini folder... This has worked for the EFIS pressure settings and Fuel weight but there are other settings I would like to change and cannot find in the document.
Can anyone provide some insight into this?
  • If the ini is not allowing you to save changes then it means that you do not have rights to make changes.
    I suggest looking into providing full control to allow changes to be made.
    Regarding CPAN changes you can attempt making the changes before loading the Q400 in the sim. However be sure to click APPLY to ensure the changes are made.
