Sticky ground
Noticed on my freshly installed 1_025 PRO, that taxi is a bit more challenging that it used to be.
It is like driving in the mud, as long as power is slightly reduced plane stops immediately, like there is no inertia force.
Anyone else feels same? ( Sim is P3D5.4 )
    I don't see this either in 5.4 nor in 6.1.
    Have you checked the calibration of your brakes?
  • Yes, my MFG are regularly calibrated
  • Sounds like your brakes may not be properly calibrated. If you have a null zone set then you may check to see if that could be causing the issue.
    I have experienced this in the past and realized that it was the brakes not being correctly setup. Not sure what utility within the simulator you use for calibrating your controls, but each one has its unique parameters.
  • My brakes are correctly calibrated and confirmed by Control Panel\ Flight Control section.
    'Muddy' feeling is subjective, will observe more as soon as my plane will be operational again :-)
