Control Panel problems
HELP, please. I am trying to set my engine controls using the control panel, but it does not seem to recognize my Saitek Yoke or Pro Flight Quadrant. When I load the aircraft, and then load the CPAN, FSX goes into pause mode, and moving the control levers has no effect on the Power lever or Condition Lever readouts. I am using the aircraft and the CPAN as the administrator. I have turned off my registered copy of FUSIPC but do fly with EZDOK and SPAD. This is the configuration I have always used, and this problem did not crop up until my hard drive died and I had to get a new one and completely rebuild my FSX-SE and add back all the aircraft that I flew. The Dash is one of my favorites, and not being able to calibrate the controls is a giant bummer. Any help would be appreciated.
  • edited March 2025
    Depending on your controls configuration you have to have the controls axii mapped in FSX-SE or FSUIPC if that is your go-to controls application. Unless you are using the 125 Hz controls configuration.
