Elevator trim pinned full nose down
Hello, version 1.026a on Prepar3D v5.3. After takeoff I activate the autopilot, and the elevator trim drives to full ND. The airplane handles normally with autopilot. When I disable the autopilot at the final approach fix, even full ND trim is not enough to keep the nose from rising, and I need significant forward pressure to keep the nose level. This is at nearly all airspeeds and flap settings.
If I recall you created a similar discussion previously -
https://majesticsoftware.com/forums/discussion/comment/5922#Comment_5922
