Heading Sel Issue
I had this issue in the Pilot version and it continues in the Pro version as well. After take off and engage the AP, the Head Sel is engaged for vectors on departure, works OK. But after flying on FMS to the departure airport and ATC vectors us for approach, the Head Sel will not work properly. If you are flying on a heading of 270 and ATC gives you a heading of 330, if you adjust the Head Sel to 330, it usually drops back 10, 20 30 degrees on its own. Sometimes it will go back beyond your previous heading. If you move the Head Sel in small increments of about 5 degrees, till you get to your new heading it seems to help, any help would be appreciated. Thanks.
