First failure with Q400 Pro
Hello everyone
That's it, first failure on the Q400 Pro and I'm a little stuck ...
At the opening of the P3D, as soon as the dashboard appears on the screen, there is a loud metallic noise, the nose goes down sharply and the message "default failures initiated" appears in the small green banner at the top of the screen. . I guess it must be a hydraulic problem in the front gear but I do not know what to do ...
I have not (yet) found any clear explanations about fault management. I admit to not understanding almost anything in the "Panel System". Is this where the problem must be solved or aboard the plane ???
A little help would be welcome
zinj
I suspect you are trying to say that you do not see your landing gear. If this is the case then you are experiencing a "protection" problem. Kindly uninstall the aircraft and then reinstall using Administrator Rights by right-clicking on the installer
