Control Panel Issue
Q400 loads up ok into P3Dv4.3 and flys ok. However when I start Control Panel ( .as Admin) all boxes are blank and I am unable to type in any data( Passenger Nos etc)
Any ideas on what may fix this. I have tried a complete uninstall and re install of the Dash 8 with no success.
  • Have you installed the Q400 using administrative rights by right clicking on the insllaer?
  • Uninstalled and right clicked on the .exe file.
    Still the same results ?
  • Further comment on this problem,could this be SimConnect issue?
  • It could be, have you tried to re-install your Simconnect modules that came with P3D?
  • No ! Where would I find this module to re install it ?
  • Hi kroswynd,
    Re Un installed and re Installed Q400 again, making sure I right clicked to install as Adminisrator!
    Seems to have fixed the problem this time ??
    Thanks for your help
  • Thank you for the update
