Frame rate decrease
Im using pro edition with 2 screens:
https://ibb.co/n8NQgd
I can move 2 popups without any problem.
But when i try to move the 3th, the frame rate decrease from 60 to 30...
This didnt happen in pilot edition...
Do you know if it's possible to fix this?
Thank you!
  • Not knowing the details of your setup one is not able to provide a definitive answer. However, getting an fps of 30 with more than 3 active un-docked screens (theoretically) is not that bad bearing in mind that the PILOT or PRO versions while possessing the capability of un-docking screens was not one of the primary purpose functions we tested an made optimizations with multiple un-docked screens in use.
    I have done a few professional installations using the PRO Edition but we used a client system which will be available ONLY in the upcoming TRAINING Edition which is primarily designed of the cockpit builder will have a specific feature geared to multiple EFIS screen usage.
