Hotas warthog
How can I connect the warthog hotas so that the keys talk to the plane? I tried with fsuipc5 (registered) but with macros mouse crashes. Linda 3.0.5 instead does not work with q-400.
some advice?
  • For LINDA issues we would recommend reaching out to the Linda developer. Depending on the version of the Q400 that you are using there is an Excel file with variables that one can use to bind functionality to the aircraft.
