Strange happenings !
I have just upgraded from P3D v3 to P3Dv4 (64 bit) pilot addition.
I uninstalled my old version from V3 before installing my new purchase of the Dash into V4.I then used the 1.20 A patch to update the 1.20 download from FSpilot shop.
Everything seems to go well until about 5 minutes into the flight when my views lock up (using EDokv2).
I thought it may have been a EZdok problem but I have noticed that when this happens EZdok and also Activesky disappear from the add-on list.
If anyone has any ideas please ?
P3d v4.3
W10 64 op sys
Steve
Are you able to operate the Q400 with both addons (activesky and EZDOK) disabled?
All sorted thanks
It was not any fault with the Dash.
It seems that i had uninstalled another aircraft and when i checked the DLL + XML files that aircraft had left behind an entry .After this was removed everything is now working fine
Sorry for wasting your time
Steve
Good to hear that you are back on track.
Thanks for the update Steve
