Default failure initiated
Hi! That message appear when I load the airplane for a flight. Than, after everything as been done and ready to go the motors suddenly stopts??? I understand that it is a failure, but it as not been planned??? Why is this failure happen? is it normal? And what to do to prevent that to re-happen again?
  • The green info bar "Default Failures Initiated" will be displayed each time the aircraft is loaded as a notification that the script has been successfully loaded. Now the engines of the aircraft will more than likely be shut down as the aircraft more than likely is loaded in the "Boarding" state (by default), and one can always use the CPAN to change panel states provided that you have the PRO Edition of the MJC Q00.
  • I had the information in another forum. I have the Pro Edition. Your comment is appreciated thank you.
