majestic q400 erreurs
hey geys what is the solution ????
  • Advisable to uninstall and reinstall using administrative rights by right clicking on the installer and choose run as administrator.
  • i do it and nothing is change
  • Look at this page from Reddit. Follow the instructions precisely. He is using P3D, but the filenames would be quite similar in FSX.
  • His problem is not based on the freighter model loading correctly... The aircraft is loading incorrectly which is a protection issue.
    Kindly be sure to disable any anti virus software prior to installing the Q400 using the administrative rights.
