Tutorial flight.
Can anyone please tell me where to put the tutorial folder in P3Dv4? It says in the read me to put it in the Flight Sim X Documents which doesn't help.
Also, I haven't been able to locate the user manual yet, a pointer to that would be welcome too. It probably tells me in there but as I can't find it.......
Lee
  • The documents for the Q400 are located in the docs folder which is located in the aircraft folder *mjc8q400 *
    Regarding the placement of the tutorial, this can be placed in the prepar3d folder which should be located in your My Documents folder
  • Thanks, I'll find it.
