Server problem ?
Could you please confirm a problem with the server ?
I am trying to re-install pilot version into P3Dv4.4 but i keep getting a "cannot connect to server" message.
I have tried a fresh download from FSPilot shop with the same result.
Steve
  • Yeah the activation server appears to be down. :/
  • Hello Steve,
    Apologies for the inconvenience that this may be causing. However, the server appears to be up and running. Are you using all of the correct credentials used for the purchase of the Q400?
    If you continue having issues kindly contact us via our Support department *support (at) majesticsoftware (dot) com *
  • edited November 2018
    have also this problem. Fill in all details correct. Firewall and antivir disabled.
    Message : CAN NOT CONNECT SERVER. :-(
    UPDATE : now it works.
  • All good now Thanks
    Perhaps it was the server in need of a rest :)
