Sending Fuel/Weight Data From MJC Control Panel Causes Sound/Switches To Stop Working
When I load up the aircraft (P3D v4.3) everything works fine and all sounds and switches work. When I open up the control panel to load weight/fuel (run it as administrator), as soon as I press 'send data to flightsim' the sounds stop working and any switch presses aren't registered (overhead panel) while the rest of the buttons on the FMS still work and the aircraft is still active. Is there a way to fix this?
Edit: Re-installed the plane and it seems to be fixed.
  • Do not forget to "UN_PAUSE" the simulator after sending your data from the Control Panel to the simulator
