ALT MISMATCH
How does one correct ALT MISMATCH on PFD? Both pressure settings on PFD and Standby are on same setting.
  • Within you EFIS section of the mjc84.ini you will have to set the switch to 1 to enabling both altimeter settings to be sync'd
    [EFIS]
    ; 1 to syncronize pilot and copilot side altimeter settings
    PFD_QNH_SYNC=1
