SPEED RESTRICTIONS & LIMITATIONS!!!
Flaps Extended Speed (VFE)
Flaps 5°. .................................................................................... 200 KIAS
Flaps 10°. .................................................................................. 181 KIAS
Flaps 15°. .................................................................................. 172 KIAS
Flaps 35°. .................................................................................. 158 KIAS
Landing Gear Operating Speed (VLO)
The maximum speed at which it is safe to extend or retract the landing gear is 200 KIAS.
Landing Gear Extended Speed (VLE)
The maximum speed at which the airplane can be safely flown with landing gear extended is 215 KIAS.
Rough Air Speed
The maximum airspeed for flight in severe turbulence is 210 KIAS.
Alternate Gear Extension Speed
Under this mode of extension, speed is limited to 185 KIAS because all wheel well doors remain open after gear is fully down.
Maximum Tire Speed
Maximum tire speed is 182 knots groundspeed.
Maximum Operating Speed (VMO)
This speed limit must not be deliberately exceeded in any regime of flight (climb, cruise, or descent) unless a higher speed is authorized for flight test or Pilot training. VMO varies linearly between the given altitudes.
0 to 8,000 ft. . ............................................................................ 245 KIAS
10,000 ft. ................................................................................... 282 KIAS
18,000 ft. ................................................................................... 286 KIAS
20,000 ft. ................................................................................... 275 KIAS
25,000 ft. ................................................................................... 248 KIAS
