Issue with Alt dial [RESOLVED]
I have recently upgraded my dash 8 to the 64 bit version to use with prepar3d v4. Unfortunately I have an issue with the alt sel knob, when I scroll it goes up a little bit but then always jumps back down to 0. I have tried reinstalling, i also have the latest patch etc but nothing fixes it. Any help appreciated.
  • I'm experiencing the same issue after having to reinstall the entire system/sim. Used to work perfectly before the reinstall. So it's good to know I'm not the only one.
    Might be some Windows 10 / NET framework issue since it used to work before my new installation. Would also appreciate help on this issue.
  • For me the solution was to set the units in P3D V4 to hybrid (feet/milibars). Was set to metric before. Solution is stated in the faq section.
  • This issue of the selected Altitude is jumping back to 0 is corrected by: Modifying the units setting to feet+inches, or feet+millibars within your simulation platform settings
