"Send Data to Flight Sim" silencing cockpit sounds in P3Dv4.4
The MJC8Q400 Control Panel is causing the cockpit sound in P3dv4.4 to go silent after calculating and sending flight data from the control panel to the simulator. This issue never occurred for me with the 32 bit version so I'm not sure what the fix is. The data is going into the simulator, as reflected in the fuel and balance page of P3d.
My fix so far has been to send the data via SimConnect, save the flight, and then reload P3D. It's not ideal, but better than unrealistic numbers causing the bird to fall out of the sky. And, the sounds are too good to not have during flight.
Simply "UN-PAUSE" the simulator using the "P" key. Sending data to the Q400 via the CPAN will pause the simulator, and this is by design.
cheers
I figured it would be something simple. I have so many programs that send outside information to the sim that pausing it never occurred to me.
