Lost sound during my flight
edited January 2019 in Customer support
Today I tried to start a fligth with the dash. I used the controlpanel to configer the aircraft and then I started with programming the FMC and everything worked fine so far. But during the flight 5 min after take off the sound was lost. Normal P3D-Sound was working. Cockpit and engine sound was killed. Do anybody know that problem?
My System: Z370, Intel i7 9700k, Nividia 1070i. Windows 10 Prof. and P3Dv4 (newest version)
  • Hello, I experienced 2 times the same and discovered finally that Options/Slew Mode was activated. No idea why. Maybe I hit something without knowing. After deactivating Slew Mode the Sound was back. Hope this hint helps.
  • Thank for finding the cause of your issue. The slew mode will certainly disable sound but should also put your aircraft in a motionless state, unless manipulated via keyboard or joystick input for movement.
    If you have not already so, be sure to download the patch available via the User Area.
