Flight Plan Waypoints / Airways not recognised
I have a Navigraph subscription (currently Airac 1901). I create a flightplan in SimBrief, which analyses and validates correctly, and manually enter the flightplan in the Dash FMC. Some of the waypoints and airways are not recognised. I have tried installing the navigation data (by Navigraph download) in the folder location suggested by the Navigraph download process and, when that failed, deleted and reinstalled in a more intuitive SimObjects/Airplanes location. Neither works properly. Has anyone come across this and / or got any suggestions for a fix?
Giving an example or route would be appreciated.
SimBrief route from East Midlands (EGNX) to Pisa (LIRP)
DTY3N DTY M605 FINMA WCO MID UL612 MILPA UM135 LURAG OBUXA TOP NEDED L50 KONER KONE1R
Seems to work fine -
Thanks. It must be me (or my installation) then. Although I'm having the same problem with a PMDG 737 others also report it working fine. I see you are using P3D. I'm on Steam (FSX-SE). When I install the Navigraph data for the Dash and the 737, the default locations for unzipping the files is different. I assume that's normal.
Sorry. Forgot to 'sign'. Andrew.
Example:
E:\Flight Simulator X\steamapps\common\FSX\SimObjects\Airplanes\mjc8q400\nav
