ctd with weather radar
I’ve been running into a issue with the q400 when I’ve finished pushing back I select the on position for the weather radar and if I try and scroll back to any of the other points for the weather radar the game freezes and crashes to the desktop.
  • Go to your SimObjects\Airplanes\mjc8q400\ini folder and open the mjc84.ini in notepad. Right at the top there should be 2 lines. ASN_INTERFACE=0 and WXAR_INTERFACE=1. Make sure the WXAR_INTERFACE is set to 0."
    If you are using active sky for weather generation the be sure to change ASN_INTERFACE=0 to 1, if it is not already set to 1
    Keep us posted regarding the outcome
  • That seems to have worked thank you sorry never got a notification
