Flight deck sounds vs voice
Hello - I run the Q400 on FSX using its ability to separate sound channels for aircraft sounds and voice: the aircraft sounds go over speakers, the voice over headphones - to make it more realistic. I noted that the Q400 communications with ground crew for pushback come through as "aircraft sound" (ie they are routed to the speakers), whereas I imagine in real life they would be coming in over the headphones.
Would it be possible in some future update to have these voices handled as - well - "voice", so that FSX can channel them correctly?
Thanks for considering!
Marcel Durieux
Had not given it any thought, but we could possibly see what is feasible down the line.
Thank you. That's great.
