Condition levers
Good afternoon to all,
As I write on title, the condition levers seems tto have becomed crazy, the move up and down suddently and almost continously.
I have deleted the aircraft and again download and set, but the problem is still there.
Fly "touching" continously the levers to set them on the right position is really exasperating, and during approach...
Many tks for any type of help
  • Providing us with some additional information regarding your setup could be beneficial in allowing us to figure out what may be causing your issue.
  • Sorry kroswynd
    Do you mean the "aircraft.cfg?
    Tks
  • Not necessarily, but are you using P3D or FSUIPC to control your joystick device axii, if so how are they configured, or are you using the mouse/keyboard.
  • FSUIPC
    Axis Assignement: "Send to FS as normal axis"
    Check, if your sim has assigned these axis automatically also directly in the sim. Then you might have conflicting assignments. The sim does such assignments from time to time.
  • In addition, have you been sure to configure your input devices via the Control panel as this is pertinent to ensure proper functionality of your axii in relation to the aircraft.
  • Many tks, the problem is solved, it was conflicting assignements between Prepar and FSUIPC
    Tks again
