CTD after update when open flight plan
When I will open a flight plan in the FMC the sim crash
  • Do you mean a saved flight plan?
  • yes. before the update everything works fine
  • Remove/backup previously save flight plans, and try again. Due to some the the updates for the FMS some older flight plans could cause some issues.
  • Ok, works. I deleted all flightplans, made a new with simbrief, imported it and it works.
