how to repair damaged tire
I have the pro version of the q400 (p3d v4.3). Last evening while doing a flight to EGPB I forgot to turn on the window heat. It was raining and everything was very misty (poor visibility). Anyway I managed to get her on down but the landing was hard and I was unable to steer after it came to a stop. When I switched to an external view I noticed my left rear tires were damaged (off the rim). Question is how do I go about fixing those? I didn't see any option for maintenance on the MCDU.
In real life one can not fix a tyre from a FMS (not MCDU)
There are two ways in which this can be solved
1. Reloading the aircraft (not the sim)
2. Waiting twenty minutes for the repair to be completed....(in real life it takes about 45 min to an hour to R&R and main tyre)
Information regarding special features is included on the Special Features pdf located in the docs folder.
put the computer into its highest speed (hit R+++++++) then the repair will only take a minute!
Nigel
Vancouver
LOL....well that is one way to do it
Nice r++++++++++. Will definitely remember that one
