Setup of joystick keys not working
I'm trying to set up controls for my Thrustmast HOTAS. The 125hz controls work, so I can use the Ailerons, Elevators and Rudder without any issues. However I cannot get the aircraft to recognize the key inputs or the throttles to respond to the setup in the mjc84ini
I'm running P3Dv4.5 hf2, and 1.020b of the Q400 Pro
; Ailerons
; Elevators
; Rudder
J1_Z=FlightControls_->sensors.Rudder0_ADC
J2_Rz=FADEC_->FADEC_engines[0].controls.throttle
J2_Z=FADEC_->FADEC_engines[1].controls.throttle
J0_b4=AFCS_->inputs.AP_disengage
J2_B3=AFCS_->inputs.GA_button
Thanks, but that's not it. I've moved it down, and even tried pressing all the buttons on the stick. To no avail.
