Install not allowing valid Order No.
edited February 2020 in Customer support
Majestic has on file XXXXXX as valid order. Installed a number of times. Today not recognized.
xxxxxxxxx@gmail.com
last name McDonald
  • The original installs but the 64Bit version does not.
  • You have just exposed you credentials to the entire viewing audience.
    The reason the 64bit may not be installing is because you are attempting to use the credentials for your 32 bit installation. Search you emails or the vendor from which you purchased the 64 bit version and use the correct
  • Doh! Use a 64-bit password and all will be well...
