P3d v4.5 Install issue
Normally I can nut issues like this but having some problems here.
I recently reinstalled p3dv4.5 after some time away and Cant get the Q400 Pilot edition to install correctly. I can open the aircraft in the sim but controls are hard over to the left, no sound, throttles etc not responding. Also strangely there is a shaking from viewpoint. No screens display anything and battery switch moves but unresponsive. Legit copy.
P3d 4.5 vanilla with Orbx Australia V2 installed
I installed 4x simconnect redistributes pictured but no joy
Any info appreciated.
Dale
  • Hello Dale,
    For starters, have you installed the Q400 using Administrator Rights? Also, what version of the Q400 are running - 32bit (not P3 d v4.x compatible) or the 64bit which is P3D v4.x compliant?
    Yes I installed using Admin rights. Good question on 32 v 64, I purchased in 2013 so originally 32 bit purchase. I downloaded installer from justflight yesterday and had P3d 3.3 and above as an option but no P3d 4+
    Is there a separate purchase for 64 bit version?
    Cheers, Dale
  • Yes there is. P3D v4.x will have t o be purchased as most of the code had to be re-worked to be compliant with he 64bit architecture. You should still qualify for the upgrade fee on their site.
  • Thanks for your Help, will upgrade now!
    Cheers, Dale
