Controls not fluid.
Is that normal that the refresh rate of the yoke movements makes it not fluid?
Just bought the aircraft btw and it is simply amazing.
  • If you are using the default P3D/FSX controls then, unfortunately, it is a SIM related issue, which is why we have allowed for users to implement the 125Hz controls (if you OWN the PRO Edition or higher). Instructions for implementing it are in the manuals provided with the PRO edition.
    Glad that you are enjoying the aircraft.
