P3d 4.5 Shared Flight Deck hard freeze of sim when pressing switches
3 times during a shared cockpit session I was flipping a switch on the overhead, a different switch every time, and my P3D had a hard freeze with the mouse cursor spinning and the sim not responding. I can complete all my flights alone with no errors but shared cockpit is causing a freeze of P3D. I am using Prepar3d V4 Hotfix 3. What kind of things can I fix or change to try to prevent that freeze? Thanks.
I was the connecting party to the host and our ports are open and the first flight we did was successful. The past 3 flights since have been freezes during preflight or pushback was not possibly to get in the air before freezes.
Your issue is not a common one, and you may have to supply some more information to allow us to assist.
Are you using the default MAJESTIC connection tool?
Have both you and sim partner tried connecting with no other third party utilities running the background? This way you can eliminate any other add-on being the possible culprit.
