Axis problem
Hi!
I configured ini file with 125Hz. Ailerons=J0_X, Elevators=J0_Y, Rudder=J0_Rz. But the nose gear is moving in the sim with my joystick on axis X, not on axis Rz. Tiller doesn't change position in Control Panel. Steering Control Mode: Ailerons+Mouse. Steering is ON in the VC. How can I connect nose gear to Rz?
  • Nose wheel steering in the Q400 is not like the average simulated aircraft which is controlled by the rudder pedals, which in this case is what you are trying to accomplish. You will get some movement +/- 12 degrees with the duffer pedals but it will not be enough to command tight turns. Hence the reason you have to configure your nose wheel steering via one of the modes provided in the CPAN, which will be the ailerons or if you have a separate joystick assigning the spolier axis to it.
