Navigraph AIRAC update issue
Hi All,
For some reason I can't get the latest AIRAC update to install and show in the FMS. Can someone tell me which file I should have the Navigraph data manager pointing to?
  • The folder it should be pointing to is is the NAV folder located in the mjcq400 root folder.
  • Hi Kroswynd,
    I'll give that a go, thank you.
  • Hi kroswind,
    I've tried to update pointing the update to the nav folder,
    Prepar3D v4\SimObjects\Airplanes\mj8q400\nav
    When I start the FMC the nav data expiry date on the screen is 11-Oct-17
    Not sure what I'm doing wrong.
  • Navigraph offers a free airac manager program of their own that takes care of that for you, I did it just this afternoon.
