GPU disappear after slew
edited June 2020 in Customer support
Hello! I'm using Dash8 1.020b and P3D 4.5HF3.
After loading the aircraft and do a short slew, the GPU will shutdown and disappear and I'm not longer able to power on the FMC's.
I see this problem first on P3D 4.5 HF3.
  • It is possible that due to the aircraft being slewed the aircraft logic may have sensed that the aircraft is airborne due to the slew function. Re-powering the aircraft via the batteries should allow you to re-power everything.
    No it's not possible I treid all.
    After the GPU disappear, I can turn on batteries but cannot turn on FMC's to bring the GPU back into the game.
    This problem occurs since HF3 of P3D.
  • I will have to look at HF3 on v4 once I get a chance to re-install it for verification. Thanks for the information regarding this.
