p3d v 4.5 HF3 Rudder trim not responding
Pretty much as the headline says, clicking the rudder trim switch on the panel makes no difference, the rudder stays at neutral. The button animation does work but it has zero effect on either the indicator needle or the actual flight model
  • I know have been a longtime flyer of the Q400, but are noticing this with power being supplied to the aircraft. I have just done a verification check on my end (ground and in the air) and it appears to be working as it should in v4.5 HF3
  • Yes, been around since the very first freeware fanda dash-8....
    Anyway, got this one sorted out by reinstalling. My initial mistake, I recon, was installing the current version on top of the existing one rather than removing the latter first.
    This one can be tagged as "resolved".
  • Ah ok, good to know... Thanks for the update
  • I too have the same issue but using the PRO version in P3D V5. The same as the person above. This is a new install into V5.
    Keith
