P3Dv5 HF2 and 1.021
Hi there,
P3Dv5 is loading the scenery, then the plane ... And then close and goes back to desktop.
  • No error message.
  • Installed in P3Dv5 folder
  • Same behavior if load a default flight with a default plane
Any idea ?
Thanks !
oliver
  • It seems to happen when view is changed.
    inside to outside -> P3D crash and exit
    outside to inside -> P3D crash and exit
    With ChasePlane or not -> P3D crash and exit
  • I've just installed the patch. No more CTD when loading the plane ... Thank you !
  • Thanks for the update
  • You're welcome ... It's nice to say when all is ok too ! ;)
  • patch for PRO v1.021 available separately?
  • The patch we released was for the PILOT Edition as there were multiple users experiencing ctds.
    There will be a patch available in the user area shortly for the blank panel issue for the syspan.
