P3DV5 Installer for boxed PILOT edition
Dear all,
how can I get the P3DV5 Installer for the Aerosoft/Justflight boxed Pilot Edition?
Best regards,
Razorback
  • You'll have to check with the respective vendors from which you purchased the Q400 to see if you have the correct version which will allow for the free upgrade for the version 5 installer. If you are currently not on the 64bit version of the Q400 then you will have to purchase the upgrade to the 64bit platform before being able to get the v5 installer.
  • Hello kroswynd,
    thank you for the answer,
    I have the 64bit version for P3D V4.
    Is this version applicable for the free V5 installer and if so where do I get it?
    Greetings,
    Razor
  • As I mentioned in my previous post you will have to check with the vendor from which your purchased the Q400. A boxed version of the v5 install may not be available though. You will have to get the specifics from the respective vendor.
