Map Lights
Hi Support Team,
When I switch on the map lights above the little drop down tables at the left and right side of the cockpit, I can see that the light is on with the bluish tinge around the physical light, but there is no physical light splash onto the map table.
Ken
  • Will have another look at that but since there is nothing that is placed on that table the light does not serve a purpose as such. Assuming you are using v5, there have been changes to the light is handled and this be one of the affected modules.
  • Yes, sorry, V5. A lthough nothing is placed on the tables, the light added to the ambience on the fligthdeck.
    Ken
